segundo a supersoundone existem 4 tipos de V6:
a dynavin so menciona D99:
o jeff já fez a review:
Source Selection Home Screen
There are two screens here, you can "swipe" the screen back and forth, the (probably) most common sources (radio, ipod, phone, etc) are on page one with the less common sources (USB, TV, etc) on page 2. You can also access the settings from here. I like the large clear buttons, it makes finding a source while driving quite a bit easier.
Settings Screen
As in the past the Dynavin has a fairly simple audio feature set, no fancy 32 band EQs or time alignment here....similar to stock, bass, treble, fader, balance. It does have a separate sub level control for the subwoofer RCA outputs for those running aftermarket subs.
One thing to point out in these menus as it is often missed.... the "DIM" function affects how the screen dims for night driving, you active this by HOLDING down the MUTE button, changing the DIM setting makes the screen dim or shut off completely depending on your preference.
Radio
The new radio interface is all big, clear, easy to press, touch screen buttons. The white text on a black background is also good for visibility. The radio can be configured to tune in US, Euro, or Asian frequencies. Pretty much works as expected.
Bluetooth
Dynavin has teamed with Parrot on the bluetooth. This adds phonebook functionality to the unit. It paired with my iphone within seconds and my phonbook was there and ready to use a few seconds after that, no need to do anything extra, it was just there. There is a keyboard for alphabetical search, you just start to type and once you are a few letters in you should see the contact that you are looking for. As far as quality goes, that is up to your mic location, your phone, your voice, how loud your car is, and a bunch of other variables. I personally had pretty good results putting the mic in the factory location but your results may vary.
Bluetooth streaming works as it has on previous dynavin units, although now with a slightly better layout of play/stop/track controls.
iPod
The iPod interface is an improvement over past dynavin versions but isnt perfect. It DOES have the ipod resume feature missing in the older units. So when you start your car, the ipod will start where you left off. As you can see in the video and pic above there are page forward and back buttons, and the menu button goes back a level. Holding down the menu button jumps back to the playlist/artist/album/etc... screen. While you can page forward and back there is no "alphabetical" search so if you have A LOT of artists it could be problematic, I have a couple hundred on my ipod and it isnt a problem but I can imagine it would get tedious if you had a thousand... If this is a problem for you consider getting an android unit and use the android media player and a SD card for you music instead as it DOES allow for more rapid scrolling.....
CD/DVD
SD/USB
The CD player and SD/USB digital interface are carry over from the D95 units and just like in the D95 they are cosmetically different than the other sources. That said, the SD/USB does require a different type of interface as it is folder dependent. I havent tested it yet to see if it has any limitations in levels of folder navigation, number of files etc...
Navigation WinCE
This is a screen shot of a WinCE unit running the Sygic Drive navigation program (a licensed copy comes with the units we sell but this may vary by dealer). The WinCE units will run any number of WinCE compatible nav programs, iGo Primo is a popular one here among the forum members, there are other threads dedicated to those other programs.
Navigation Android
The Nav setup on an android unit is totally different......read the original android thread for details, http://forum.e46fanatics.com/showthread.php?t=839753 and if you dont you do so at your own risk!
e depois temos a versao D95 (ECO):
mais uma vez a review do jeff:
menu principal:
iPod/iPhone:
DVD/CD/USB/MP3
Bluetooth:
Setup:
"Hidden" factory settings menu:
o D99 claramente a ganhar pela melhoria no ipod e no bluetooth parrot. o hardware é melhor e existem ofertas bem interessantes..
um video do D99:
http://www.youtube.com/watch?v=k2S2iBKPwFQ
:think
